Call a Help File (.chm) when Press a button on Front Panel
I can't call a Help File (.chm) when Press a Button on Front Panel. I only call it when press a Key then click right mouse and selected Key navigate for Button.
(3,313 Views)
This part is not so clear to me.
But, have you coded the calling .chm file part inside the Value Change event of that button?
If not try this out using the Event Structure & post back here.
If you post your code here, somebody may help you out reg what has gone wrong.
- Partha ( CLD until Oct 2027 🙂 )
(3,300 Views)
