Call a dynamical VI doesn't work
i just decided to change the call to a capacious vi from static to
dynamical. I had made some same things with LabVIEW 5.x some time ago.
But with 6i i run in trouble. I opened a vi reference and wanted to wire
it to the dynamic function call. In that case i always get a dotted
line. I also tried to specify the typ for open vi, but nothing helped.
Where is the mistake and how could i resolve the problem?
Regards
Henrik
(2,717 Views)
Ok, after advice i found an example which uses this function. I missed
the entry to browse for the vi control to the open vi.
Now it runs perfect...
Henrik
Henrik Skupin schrieb:
> Hi,
> Regards
> Henrik
(2,717 Views)
