Call by Reference Node with strict type of nested class
i'm migrate to Labview 2010,
i define a class DPM and a class MANAGER.
The Manager contains a DPM.
The DPM has a run() function and a RefDPM attributes (strict type of the VI function).
The run function try a Call by Reference Node on a VI with strict type.
This VI has two input parameters: A DPM and a MANAGER.
The problem is:
Labview compilateur does not want to compile the DPM class because of the VI strict Ref.
This work perfectly with Labview 2009.
Does Labview change its policy about Labview 2010 ??
Message 1 of 23
(3,903 Views)
A very highly "dumbed-down" example would help greatly in undersatnding this question properly.
I have heard of no changes (yet!).
Ben
Message 2 of 23
(3,899 Views)
Yes, here the code view
Message 3 of 23
(3,887 Views)
Simply, i want to run dynamically a VI module with nested class input parameters.
Message 4 of 23
(3,881 Views)
Does it helps you ?
Message 5 of 23
(3,860 Views)
What error when you float over that wire with the wire tool?
Have you tried right-clicking on the call by ref and selecting "adapt to type"? (Forgive me if that doesn't exist. I am answering from memory).
I still think that if yo uposted a small zip that works in 2009 and not in 2010 may help somebody (don't have 2010 on any machine yet).
Ben
Message 6 of 23
(3,857 Views)
The errors are: (Translated into English)
CallByReferenceNode: Contains bad terminals or unwired terminals.
Wire: the input reference of CallByReferenceNode must be a strict reference of VI.
When i try to use a direct reference its working (like image_1).
In this case, i must suppress the reference in the DPM, and here there no more error. (image_2)
But of course the reference is open dynamically so i want to keep a link on my dynamic VI.
Can not i use a strict ref which include self-class ?
Best regards.
PS: the project is really huge size to be zipped.
Message 7 of 23
(3,822 Views)
Will a type cast work?
Ben
Message 8 of 23
(3,809 Views)
OK, i have build a small example.
In LV_2009 there is no compilation error.
In LV_2010, the example does not compile.
Open the project, and just check the two class .cpl to see if compilation is right.
Message 9 of 23
(3,806 Views)
lacking 2010 I will have to step aside and let someone else try this out.
Ben
Message 10 of 23
(3,797 Views)
