Call dll (a simple gui for user) from c#
Hi at All,
i'm trying to modify you Setparameter VI and Dialog VI adding only one double parameter.....but when I start the C# project it doesn't works....
and the error said me "" BadImageFormatException"....I don't understand what I'm wronging??
Thank you
Message 11 of 14
(1,820 Views)
I am trying to make same. i am coding c# but i am not familiar with labview.i used this one first:
http://zone.ni.com/devzone/cda/epd/p/id/3838
it worked but i could not make it work for my fsk sample. this sample gets only 2 variables.
Then i saw this link:
http://zone.ni.com/devzone/cda/epd/p/id/4338#0requirements
and sample in this topic
When i try to use these i, get same error for both
I searced but i could not find solution. These are i tried according to my search:
- Installed again
- I tried in other PC
- Check windows and program both are 32 bit
- Make updates
Also find this but there is not option like they wrote in installation:
http://digital.ni.com/public.nsf/allkb/EDC260CE918A990E86257543007BCDD3
and i installed these:
LabVIEW 2011
LabVIEW for ARM 2011
NI LabVIEW Modulation Toolkit
LabVIEW Run-Time Engine 2012 ( http://joule.ni.com/nidu/cds/view/p/id/3433/lang/en )
i have to make this work in few days any help is appreciated.
Message 12 of 14
(1,752 Views)
i installed labview 8.5 with all components it worked but my niUSRP EX FSK Tx.vi sample is for newer version.
Any tips i can do with labview 2011 do i have to install any component?
And there is no info about from where this code gets dialog.vi i tried no open dll file but i could not find any info i also searched folder there is no dialog.vi file.
Message 13 of 14
(1,737 Views)
hi your example i great and it works fine on my pc however i am trying to do something simmilar, i am creating a labview project simmilar to yours, then making a dll from it but when i try to call it from c# i get the error saying no entry point was found on dll, can you email me some more detailed information on this?
I appreciate your time
Message 14 of 14
(1,603 Views)
