Call function from "CP210xManufacturing.dll"- Silicon Labs
I am developing a production line test system that includes retrieving and setting the VID, PID, product string, serial number maximum power consumption of a Silicon Labs CP2102 USB - UART bridge using Labview 8.2.
Unfortunately I could only call one function { CP210x_GetNumbDevices() }. Wondering any one can help me to call others.
Tuong
(7,612 Views)
G'day Tuong,
I'm having issues finding the device i want (VID / PID) on my machine using the "CP210xManufacturing.dl"and calling function "CP210x_GetNumDevices()"...
Just wondering if you have any details on this....
Hahaha, I just saw the date you wrote this thread... Hmmm, I might just ask you at work tomoz...
Cheers
Tim
(6,525 Views)
devcon will help solve your problem. Post back.
(6,516 Views)
This thread is old but I am having same issue. I can get the number of devices() as it is the only function that does not require a reference handle. The problem is the open() function, which creats a reference handleto pass into all subsequent functions, is returning  "invalid handle".
Tuong/Tim did you ever figure this out?
(5,011 Views)
I did work it out.
It got do do with the "CP210xManufacturing.dll". I Down load a number of them and eventually one worked. Unfrotunately I do not work for that company any more and therefore I do not have the DLL that works. If you can contact Tim he may help you out as he is still working there, he may even send you the LV code.
(5,000 Views)
Any idea where we can get this working code? I have some similar issues and I would be grateful for a working example!
Thank you!
(1,583 Views)
