Call library function to access a dll crashes labview 2020
Hi Rolf,
Thank you very much for the solution. It works pretty great. Awesome!
This was my first experience with handling DLL in LabVIEW.
Attached the working code here.
Thank you again for your support.
Regards
Shan
Message 11 of 23
(1,729 Views)
I'm having similar issue as I transition from LabVIEW 2011 32bit to labVIEW 2020 (32bit), Before I installed LabVIEW 2020 I used labVIEW 2018 (32bit) everything worked, recently I upgraded to Labview 2020 but for some reason I cannot use previously developed software to control my hardware, oscilloscope ZT4211. I am using Call library functionality to access ZT4211 dll but when I try a particularly function, take a measurement, the whole thing crashes. I have ensured that all dependencies have been included and have performed several uninstallations and reinstallations in case I have missed something.
see ztscopeM Clear Status.vi in attached .llb
Message 12 of 23
(1,610 Views)
Likely CLFN configuration as in the previous cases, but I don't see any attachment.
Message 13 of 23
(1,601 Views)
First, there is no attachment.
Second you say there is a problem with Take Measurement. The name of this method would indicate that this function will return data and then there is a very high chance that you made the error of so many trying to venture into the Call Library Node to call a DLL. EVERY memory buffer passed to a DLL function normally needs to be preallocated before calling the function. So if you need to pass an array or string buffer to the function so it can fill in the measurement data to return to your program you need to make sure to allocate that buffer properly with the correct size before calling the function!
Rolf Kalbermatter  My Blog
Message 14 of 23
(1,586 Views)
Hello Rolf and Jim,
Here are the attachment files.
Message 15 of 23
(1,572 Views)
Please make a Save for Previous Version for the Self Test Oscilloscope.vi for version 2018 or older.
But the website for ZTEC doesn't exist anymore. Seems that company is gone and I wonder if you really want to invest any effort to get this working with hardware that seems totally unsupported and obsolete.
All I can say is that the DLL calls seems to be configured to use C calling convention. Depending how it is compiled this could be very wrong, and as the LabVIEW library seems to be in LabVIEW 2011 format and likely developed in even earlier format before 2010 so it may have worked back then but not anymore since LabVIEW 2010 and newer does not automatically detect if a DLL uses stdcall or cdecl and simply uses whatever is configure in the CLN node.
I can't check as with the company side gone I can not find documentation nor a download for the DLL itself.
Message 16 of 23
(1,567 Views)
Dear Rolf,
Thank you for your suggestions. ZTEC developed drivers for ZT42.. series. hardware is made by Teradyne and it is still supported. I'm trying to reinstall LabVIEW 2018 (32bit) because it worked without issues. If I happen to figure it out why LabVIEW 2020 is not working I will post it here.
Message 17 of 23
(1,554 Views)
Have you figured this out yet? I am also having intermittent APP Crashing with an application built in LabVIEW 2020 32 bit. I narrowed the issue down to tasks calling two different dlls from two different suppliers. It works for several hours then crashes without any errors being recorded. I am creating dump files, but there is really nothing useful in them.
Message 18 of 23
(1,535 Views)
The original problem had to do with code that worked in previous versions of LabVIEW and now fails. Is your case the same?
What you describe seems quite different and the problem with crashes when calling DLLs is that there are a zillion possible reason. While bugs in LabVIEW are not completely possible to exclude I have in my many years of calling DLLs from within LabVIEW never really had a clear LabVIEW bug that would cause it. It was always caused by badly configured Call Library Nodes and/or bugs in the DLLs itself. This leaves a lot of potential issues to be checked before you can point at something specific. The first question would be, who write the LabVIEW VIs to access those DLLs? What is their C programming expertise? If this was not done by a real C programmer, you definitely have your task carved out to first start checking every single Call Library Node to be properly configured according to the header file data types and buffer allocation requirements. After that the next step would be to isolate the DLL calls to create a test application that only does the critical calls and try to get it to crash too. Then you have something more specific to look into and even post here.
Obviously neither me nor any LabVIEW developer is going to check your huge application for any such problems. That's potentially many days or even weeks of work and not part of my job description as forum volunteer nor part of the job description of any LabVIEW developer at NI. 😀
And yes your first argument is likely but it works for hours fine before it crashes therefore it can't be a Call Library Node misconfiguration! All I can say to that is: this is a wrong assumption. Not every misconfiguration has to crash immediately. It can go on for a long time corrupting at every call some memory before the problem gets so grave that someone somewhere stumbles over the corrupt memory location in a way that causes a crash. Often such errors only get apparent when you shutdown your application and LabVIEW and LabVIEW dutifully goes and tries to deallocate all the different resources and then stumbles over the corrupted memory pointers.
Message 19 of 23
(1,528 Views)
Rolf-
Thank you for your comments. Our vendor developed in LabVIEW 2015 and claimed to not have any crashes, so it is a similar scenario although I had not mentioned this in my post.
One of the dlls is composed of .NET and the other is from a C++ application. I will attach the two here as zips. It doesn't appear to be a memory problem. I'm not sure who wrote the code for either.
I have been at this for 3 weeks and can't figure out the problem, having no real errors to go on.
Message 20 of 23
(1,520 Views)
