Call static function of .NET class in LabVIEW 8
As far as I can see, one can only invoke functions on .NET object instances from within LabVIEW. But what about static members of a class?
The System.Messaging.MessageQueue class e.g. has a static Exists() function to verify the availability/existence of an MSMQ message queue on the target machine. In C# a code line like
if (MessageQueue.Exists(@".\Private$\myOwnQ")) {...}
will do the job.
How to achieve the like in LabVIEW?
Thanks for any advise,
greets
Hans-Juergen Philippi
(3,740 Views)
No problem - just drop down the invoke node from the .NET palette. Then right click on the top-left terminal (the input refnum) and say Select->Class.
Also note that you can also invoke static methods if you have an instance - we know it's static and ignore the instance value passed in on the refnum. But if you don't have an instance, the above trick get's you going.
(3,731 Views)
Geee... that's what one should call "not seeing the wood for the trees".
Thanks for the quick and helpful response!
(3,718 Views)
