Call subvi from exe
I call an exe with system exec block. I build that exe with Labview application builder. I need  to open the front panel of some sub-vi included and I need to close them when they finish. The sub-vi node setup is configuered in this way: show front panel when called; close afterwards if originally closed. At the very first time I didn't include those sub-vi in source file tab of the application builder, so the application opened a pop-up of error. Then I include them in the source file tab: now the program works, but the VIs are all opened when the application start. I don't like that. How could I reply exactly the behaviour of VI in the exe file?
Message 1 of 11
(4,828 Views)
Accepted by topic author FabioBone
Use property nodes within the subVI itself to open and close it's front panel.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(4,824 Views)
Hello Mark,
Is it possible to close front panel of subvi from main VI??
CLAD
Passionate for LabVIEW
Message 3 of 11
(4,697 Views)
Hi jatin,
yes.
Message 4 of 11
(4,694 Views)
jatinpatel1489@gmail.com wrote:
Hello Mark,
Sure it is.  You just have to get a reference to the VI and use an invoke node to close the front panel.
Message 5 of 11
(4,692 Views)
It's even better to use Invoke nodes. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 11
(4,668 Views)
Its Great,
One more thing I am looking for is to get list of all subvis which are in memory. How do I do this ??
CLAD
Message 7 of 11
(4,641 Views)
If you drop an empty property node it's linked to Application by default, look for Application - Exported VI's in memory, or something similar.
/Y
Qestit Systems
Message 8 of 11
(4,637 Views)
My mistake in previous post actually I looking for list of subVIs having front panel opened. I should not have asked every small things but I am really not finding a way to get a list of opened sub vis. I would heartly appreciate if you could post a code or image for the same.
CLAD
Message 9 of 11
(4,619 Views)
That's a valid question, as it's not that simple. 🙂
You'll need to get the Application in memory list, loop through it and open all ref's (as shown above) and check their window property.
/Y
Qestit Systems
Message 10 of 11
(4,609 Views)
