Callback a specific function of Server VI to Client VI
Hi Everyone,
Is there any possibility of callback a specific function of one program (Server Application) to another application (Client)?
For eg., The client VI should sense or read the data only when there is a change of event from the Server VI, rather polling all the time.
**No shared global variables to be used**
Hope I made it clear with my query. Kindly help me out.
Thanks in advance
Cheers
PVK
(2,370 Views)
      Create a event structure in client program with bool as a event and just use property node (Value signalling) .This should work
(2,368 Views)
Your best bet is to just use TCP communications.  If you have a connection, then just have the server send a message to the client and the client can then react accordingly.
(2,342 Views)
