Callendar-van Dusen when I don't have extreme high and low temps
I am currently trying to use a method from the following document to calculate the coefficients alpha, delta, and beta, and ultimately A, B, and C for an RTD ftp://ftp.hartscientific.com/manuals/9933.pdf. See section 3.8.1 - 3.8.3 (inclusive).
This method is used in some hartscientific software and it gives the user the ability to get these coefficients for over-constrained system of equations even when they haven't taken data at very large and small temperatures (like you normally do to get the 4 temperatures necessary for the CVD equation).
Please see the attached snippet for data. The setpoint array is the temperatures and the data array is the resistances. When I put these values into the hart scientific program I get alpha, beta, and delta to be alpha = .003853
delta = 1.34112, beta = 4.5563.  This gives me A, B, and C to be A = .0039, B = -5.16 E -7and C = 1.7 E -10
I am trying to use this method to get these values in LabVIEW but to no avail. I also tried to go straight to A, B, and C rather than calculating alpha beta and delta first (shown in snippet) but that didn't work either. Does anyone have suggestions for what I'm doing wrong, or what I can do to get these coefficients?
Let me know if you need clarification, I know that was a bit confusing. Essentially what I want is to have the calculated coefficients in my LabVIEW code to match the coefficients calculated by the hart scientific program for the supplied data.
(3,441 Views)
I think I have gotten it (at least I got A and B, so C shouldn't be too hard). I will post my solution once I have it all figured out. Just hoping to save some time for anyone that may have decided to work on this.
(3,422 Views)
Hey for(imstuck),
I'd be interested in seeing this complete code. There is another implementation that I found where someone did these calculations using a formula node, rather than straight graphical programming. You can find that implementation here if you are still stuck finding the last coefficient. Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(3,402 Views)
Here is my method I have been trying based off the hart scientific software. With the default values I have in the controls I get respectable numbers. However, the comment on the front panel has another set of data and the output from the other software, and when I plug those numbers into my program, I get no where near their solution.
Any mathematicians out there?
(3,376 Views)
