Calling DLL from LabVIEW PDA 7.1
I have a DLL written in eMbedded VC++ 4.0 and it works well on my iPAQ when I called it from MS .NET Compact Framework.
Now I try to call it using LabVIEW PDA 7.1 module. But when I try to config the "Call Library Function Node". I got "Bad image. The application or dll is not a valid windows image. please check this against your installation diskette.".
I attached the dll and the VI. The function I called is defined as:
long TDR3125_Open(void);
(3,243 Views)
Hello yqin,
Take a look at these two Knowledge Base articles concerning the use of DLLs in LabVIEW PDA.
http://digital.ni.com/public.nsf/websearch/160BC981E2587B5486256D2F005554AA?OpenDocument
http://digital.ni.com/public.nsf/websearch/517300B49212795986256DDD00623FEE?OpenDocument
I think this information should help you out. If it doesn't, please attach a copy of the DLL you are trying to use (only the vi was attached to your last post).
E.Lee
Eric
DE For Life!
(3,226 Views)
> against your installation diskette.".\
Could it be that your DLL is really a .Net assembly instead?
rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,215 Views)
