Calling DLL problem
I have done some tests.  If I fill the array with some fixed value, the return array is always right.  I have the feeling that the problem is with the input data function.
>Hi,
>I have a LabVIEW applicaiton that calls a DLL library.  I wrote this DLL in Microsoft visual C++.  Basically, the my LabVIEW application sends data arrays into the DLL, the DLL does calculation, and later the application calls a function in DLL to get the calculation results.
>The application runs well in LabVIEW environment.  However, when I generate the binary file.  The binary doesn't work well.  What I get is always an double floating array that is filled with NAN.
>I checked my DLL source code.  In the code, all the calculations just use addition, subtraction, multiplicaiton, and division.
>Could anybody help me with this problem?
>Thanks,
>Yonggang
Message Edited by bnlgeese on 11-12-2009 11:46 PM
(3,063 Views)
I'm sorry, are you responding to a thread? Or did you start a thread somewhere, and are you posting some additional information? If so, please do it in the original thread. I honestly have no idea what you're referring to.
(3,052 Views)
