Calling LabVIEW DLL from C with 2d array strings
I am trying to write a DLL in C that calls a LabVIEW DLL that has a number of functions that each return a 2D array of strings which are the formatted measurements, with column 1 being the measurement name and column 2 being the measurement. I wanted to use the 2D array of strings since this would give a uniform interface for returning measurements. Ive cobbled together bits and pieces of messages and example code I've found here into something that almost works, and was hoping someone with a little more experience in interfacing C with LabVIEW DLLs would be able to help me.
Here's a little snippet from the header file generated when building the LabVIEW DLL:
typedef struct {
    long dimSizes[2];
    LStrHandle String[1];
} TD1;
typedef TD1 **TD1Hdl;
long __cdecl TestVI(char serialNumber[],  TD1Hdl *formattedMeasurements, char ErrorDescription[], long len);
The "TestVI" VI generates a 2D array of strings. The cell contents and number of rows are random to simulate different measurement names and measurements.
Here's a snippet for the wrapper class:
class CArgoTestsLabVIEW
   public:
      CArgoTestsLabVIEW();
      virtual ~CArgoTestsLabVIEW();
      // test modules called from parent DLL
      BOOL GetResult_LV(CString resultName, double *result);
      long TestVI_LV(CString serialNumber);
   private:
      TD1Hdl m_LVStringArray;
      CMapStringToString   m_resultMap;
      InitMeasurementsArray();
      PopulateResultMap();
The "m_LVStringArray" is intended to hold the 2D array of strings that the test modules spit out. The "m_resultMap" is just for accessing the measurements from the parent DLL via the "GetResult_LV" function.
The implementation of TestVI_LV is:
long CArgoTestsLabVIEW::TestVI_LV(CString serialNumber)
    long rc = 0;
    char errStr[BUFFERLEN];
    strcpy(errStr,"");
    rc = InitMeasurementsArray();
    if (rc == 0) {
        rc = TestVI(serialNumber.GetBuffer(serialNumber.GetLength()), &m_LVStringArray, errStr, BUFFERLEN);
    return rc;
The accessor functions InitMeasurementsArray and PopulateResultMap are:
long CArgoTestsLabVIEW::InitMeasurementsArray()
	MgErr err;
	if (m_LVStringArray)
		DSDisposeHandle(m_LVStringArray);
	m_LVStringArray = (TD1Hdl)DSNewHandle(sizeof(TD1));
        // code to check for NULL
	// Set number of strings in array to 0
	(*m_LVStringArray)->dimSizes[0] = 0;
	(*m_LVStringArray)->dimSizes[1] = 0;
	// Set total size of array structure. For now it is only as big as the long variable.
	err = DSSetHandleSize((UHandle)m_LVStringArray, sizeof(long));
	// code to check for error
	return 0;
void CArgoTestsLabVIEW::PopulateResultMap()
	int	numberOfResults;
	int i;
	int charCnt;
	numberOfResults = (*m_LVStringArray)->dimSizes[0];
	if (numberOfResults == 0) {
		return;
	m_resultMap.RemoveAll();
	for (i = 0; i < numberOfResults; i++) {
		charCnt = (*((*m_LVStringArray)->String[i * 2]))->cnt;
		(*((*m_LVStringArray)->String[i * 2]))->str[charCnt] = '\0';
		charCnt = (*((*m_LVStringArray)->String[i * 2 + 1]))->cnt;
		(*((*m_LVStringArray)->String[i * 2 + 1]))->str[charCnt] = '\0';
		m_resultMap.SetAt((LPCTSTR)  (*((*m_LVStringArray)->String[i * 2]))->str, (LPCTSTR)  (*((*m_LVStringArray)->String[i * 2 + 1]))->str);
The problem I have is that I eventually get an access violation from the run-time engine if I try to call the test VI in a loop. I'm obviously having a memory management problem, but it escapes me as to where the problem is. Anybody have any ideas?
(3,440 Views)
Hi smercurio,
      Have you solved this?  I don't work with C much anymore, but it looks, here, as if the memory at str[charCnt] isn't yours to address/change.
Is index "charCnt" one char past the end of the String-memory allocated by LabVIEW?
just an idea! Smiley Happy
Hmmm, maybe page 9 is a bit far back to fish in the unanswered posts. Smiley Tongue
Message Edited by Dynamik on 03-03-2006 02:03 AM
When they give imbeciles handicap-parking, I won't have so far to walk!
(3,363 Views)
