Calling a LAbVIEW dll from VB
I have a small LV application which monitors several temperature tranducers. To configure the display I use a sub-VI set up like a dialog box to get user input and then save the configuration. I was recently asked to compile the VI as a dll to be called from a Visual Basic program and pass the temperature readings on demand. No problem there. However, I wanted the VB program to also be able to request the dll to show the configuration dialog. This is causing major crashes (Win2K system. Is this just not possible?
(2,826 Views)
In general, having the VI open its front panel shouldn't cause any problems. I just tried it out on my Windows 2000 machine and it worked fine. I started with the example "Using Microsoft Visual Basic to Call LabVIEW DLLs That Pass Numeric Data Types" off of NIs website. I then modified the VI so that it called a subVI to show its front panel. I then rebuilt the dll and called it from Visual Basic. The front panel appeared fine and didn't crash.
Some things to note/watch out for:
1. When I defined my prototype I used standard calling convention.
2. The subVI contains a property node to show the front panel.
3. In the build script on the VI Settings tab, the subVI was configured so its front panel was not removed.
I have attached the parts of
the example that I modified for your review.
(2,826 Views)
