05-30-2006 11:33 PM
05-31-2006
02:33 PM
- last edited on
05-29-2025
08:08 AM
by
Content Cleaner
You will need the LabVIEW 8 Run-Time engine installed in order to call a dll built with LabVIEW 8. You can either download it from ni.com/downloads under Drivers and Updates, or you can package it with your executable by building an installer for your project and including the LabVIEW 8 Run-Time engine with that. Hope this helps!
05-31-2006 02:40 PM
05-31-2006
02:49 PM
- last edited on
05-29-2025
08:09 AM
by
Content Cleaner
I'm honestly surprised it's not installed. The answer is yes, you will need it. It should have installed by default along with the LabVIEW Development System, however. Try installing it from here for WinXP and let me know if this resolves this. Make sure you install the 87MB version, not the smaller version. The smaller version is only designed for viewing remote panels in web pages. You can also install it from your original LabVIEW installation CD if you don't have a quick internet connection. I suppose it's possible you selected not to install the run-time engine, but you would have had to do so manually.
05-31-2006 02:50 PM
05-31-2006
02:53 PM
- last edited on
05-29-2025
08:09 AM
by
Content Cleaner
Hi Jenn, you might try the suggestions made in this thread. It looks like it might be Microsoft bug. Let me know if this helps.
