Calling a Matlab script returns error code 1048
I don't know how to proceed. My variable names are not Matlab function names.
I'm using LabVIEW 6.1.
I'm running the following Matlab version:
» ver
MATLAB Version 6.5.0.180913a (R13)
MATLAB License Number: 156808
Operating System: Microsoft Windows 2000 Version 5.0 (Build 2195: Service Pack 2)
Java VM Version: Java 1.3.1_01 with Sun Microsystems Inc. Java HotSpot(TM) Client VM
MATLAB Version 6.5 (R13)
Simulink Version 5.0 (R13)
Communications Blockset
Version 2.5 (R13)
Communications Toolbox Version 2.1 (R13)
Control System Toolbox Version 5.2 (R13)
DSP Blockset Version 5.0 (R13)
Filter Design Toolbox Version 2.2 (R13)
Fixed-Point Blockset Version 4.0 (R13)
Image Processing Toolbox Version 3.2 (R13)
MATLAB Compiler Version 3.0 (R13)
Optimization Toolbox Version 2.2 (R13)
SB2SL (converts SystemBuild to Simu... Version 2.5 (R13)
Signal Processing Toolbox Version 6.0 (R13)
SimPowerSystems Version 2.3 (R13)
Spline Toolbox Version 3.1.1 (R13)
Stateflow Version 5.0 (R13)
System Identification Toolbox Version 5.0.2 (R13)
Wavelet T
(3,530 Views)
maybe it is better for you to send here piece of vi code rather than those informations.
We believe you have a licenced version :).
regards
Pawel
(3,530 Views)
Matt,
This error can occur if your variable name is the same as a function name in Matlab. For instance, using the variable name disp and then trying to return this variable will generate this error. To fix this, choose variable names that are not reserved names used by Matlab. See the Matlab online help or user manual for a list of reserved function names.
Zvezdana S.
(3,530 Views)
