Calling a VI from within a VI
I want to launch a VI based on a string a user inputs.  For example: if the user inputs "X", then the VI that is currently running lauch "X.vi" from the network.  I'm trying to avoid something like having a case structure with a seperate case for every VI possiblility.  I also don't want to hard code VIs in my main VI.  Any ideas?
Pat
(2,380 Views)
Accepted by topic author pd110
Search for "dynamically called VI".
(2,377 Views)
