Calling a visual basic executable with command line arguments using LABView
Hi all,
I am trying to call a visual basic executable with a command line argument using LABView 2014. What I am trying to accomplish is running an executable that communicates with a device through a com port. So, I would like to open the .exe with a command line argument to communicate through com 3 using the Systen Exec VI. It looks like the command prompt window flashes and closes and then nothing happens. Not a lot of discussions about this on the forum. Any help would be greatly appreciated. Thank you.
(4,007 Views)
Accepted by topic author FireChief16
With some programs, instead of passing in the string:
Somefile.exe
You instead need to use:
cmd /c "C:\Full Path\to the EXE\Somefile.exe"
Can you tell us what exactly you're trying to run?
(3,988 Views)
Thanks so much for the suggestion. It was a combination of needing to add the cmd /c text to the string as well as a few syntax errors in the command on my part. However, it was your reply that sent me down the right path. Much appreciated.
(3,919 Views)
