Calling library node not working
I tried following this tutorial:
http://forums.ni.com/attachments/ni/170/29800/1/dllmatlablabview.pdf
Everything worked and I got foo_wrapper.dll. When I tried using it in Labview I got the following error:
"The procedure entry point mxGetRegisterINternalFcnsFcn could not be located in the dynami link library libmx.dll."
What am I doing wrong?
(3,259 Views)
Hello Honeywell,
I looked a little at the DLL and didn't see anything that caught my eye right away.  That error is likely generated because your wrapper or functions the wrapper calls is improperly calling a DLL -- specifically the Matlab DLL named "libmx.dll".  With a Google search I found some record of that DLL and the function you are calling in a couple places.  I also recommend visiting the mathworks website for more information on this DLL and how to call its functions.
Thanks for posting and I hope this helps a little.
Travis M
Message Edited by Travis M. on 07-15-2005 10:20 AM
Travis M
LabVIEW R&D
(3,252 Views)
