Calling nilvaiu.dll from c++
I have a Labview program that will call a number DLLs written in C++. I'm trying to setup my DAQ using DAQMX so that when I call the C++ DLLs, they can in turn call the DAQRead functions from DAQMX.
Looking into a simple boolean digital readin DAQMX, it calls the DAQRead1Chan1Samp1LineBool method in nilvaiu.dll - I wrote a C++ DLL to call this instead, but I'm running into problems - see code snippet below. Is anyone able to point out where I'm going wrong?
int mydaq(int taskID, char* value)
   /* get handle to dll */
   HINSTANCE hGetProcIDDLL = LoadLibrary("nilvaiu.dll");
   /* get pointer to the function in the dll*/
   FARPROC lpfnGetProcessID = GetProcAddress(HMODULE (hGetProcIDDLL),"DAQRead1Chan1Samp1LineBool");
      Define the Function in the DLL for reuse. This is just prototyping the dll's function.
      A mock of it. Use "stdcall" for maximum compatibility.
   typedef int (__cdecl * pICFUNC)(int, long, char*, char*);
   pICFUNC DAQRead1Chan1Samp1LineBool;
   DAQRead1Chan1Samp1LineBool = pICFUNC(lpfnGetProcessID);
   /* The actual call to the function contained in the dll */
   int intMyReturnVal = DAQRead1Chan1Samp1LineBool(taskID, 1.0, value, "");
   /* Release the Dll */
   //FreeLibrary(hGetProcIDDLL);
   return true;
Cheers,
Dougie
(2,920 Views)
Never mind, needed caffeine! Problem solved Smiley Happy
int mydaq(unsigned int taskID, unsigned char* value)
   HINSTANCE hGetProcIDDLL = LoadLibrary("C:\\WINDOWS\\system32\\nilvaiu.dll");
   typedef int (__cdecl * pICFUNC)(unsigned int, double, unsigned char*, char*);
   return intMyReturnVal;
(2,909 Views)
