Camera Link Frame Grabber 1473R - not published protocol constraints?
Hello everyone!
I have some problems with a system streaming data from controller to the NI 1473R frame grabber through camera link (64-bit mode) and I wonder if there are any protocol rules I HAVE TO follow while programming controller?
What I means is:
1. Can I set all validation lines HIGH in this same time or maybe should I set them sequentially?
2. Is there any specified number of ticks Frame Valid line should be LOW between sequential frames?
I struggle with this for quite long time and I can not find these answers on the internet. There was some answers for the 2nd question on NI site but for older versions of frame grabbers.
Thank you very much for your time,
Riv
Message 1 of 1
(2,903 Views)
