Camera and picture name
Hi all, I'm taking pictures from my web camera. All is working fine, except saving picture name. Picture always saved as "image.png"; I want to save picture for example "date_time_image.png". I try to change in path, also add "string" to IMAQ, but I think the problem is at "IMAQ write".
Can aynone help me; See picture below.
_________________________
Rookie; LV 2011 on WIN 7
(3,003 Views)
File Path is the complete pathname, including drive, directory, and filename, of the file to write.
So you need a filename, not just the path.
Have a look at the build path VI (it's in the file functions pallette from memory).
Also have a look at the build string VI to build your date_time_image.png filename.
(2,995 Views)
Accepted by topic author hlod
Hi hlod
Have a look at attached snip
Silver_Shaper | CLD
(2,984 Views)
