Camera shows up in MAX on Win 7, but not on Win XP (x-post machine vision)
Hi there,
I'm using a Point Grey Blackfly USB3 camera for an application. I wrote an application on Windows 7, and deployed the executable to Windows XP.
On Windows 7 I can use the point grey frame grabber, or view the camera in MAX or my LabVIEW application without changing drivers.
On Windows XP I can use the point grey frame grabber. I installed MAX as well as my application with the IMAQdx 14.5 runtime and Vision Acquisition software, but cannot see the camera in MAX. The camera originally showed up in Device Manager as a Point Grey USB3 camera, but I can change the driver to NI-IMAQdx USB3 Vision Device, and it still does not show up in MAX.
Please let me know if you have any experience or ideas on the issue. Thank you
(3,307 Views)
Do you have USB3 drivers for WinXP?
BS
(3,232 Views)
I am not sure, how would I check that?
I can view camera images using the vendor's software. I can also browse to "C:\Program Files (x86)\National Instruments\NI-IMAQdx\Staging\NI USB3 Vision" and install the niu3vk.inf file, which changes the driver (in device manager) from Point Grey USB3 Vision Camera to NI-IMAQdx USB3 Vision Device.
(3,138 Views)
The camera is now talking to MAX!
Before I had just deployed the application and it installed the IMAQdx runtime, and the camera did not work. After popping in the Vision Acquisition CD I ran a full installation, and the camera is now working!
In LabVIEW 2013 deploying a vision application would include the IMAQdx drivers, but now in LabVIEW 2014 it deploys the IMAQdx "runtime". I am not sure what the difference is, but I never had a problem deploying applications written in 2013. I think this is the second time I tried to deploy an application in 2014 and both times resulted in complications. Last time it completely wiped out compatibility with older applications. Please take note!
(3,120 Views)
