Can Eleven Plots With Four Unrelated Y-scales Share the Same Gridlines?
I want to plot eleven waveforms on the same graph, with four unrelated y-scales and it's causing the gridspace to become cluttered. Is there a way the eleven plots can share one set of gridlines? (Without making three of them invisible or by changing the colour, this is not an option!)
I really hope someone can help me.
Thank you in advance!
(2,438 Views)
Your question rules out the normal approaches.
Before I suggest a solution let me ask what will rule out my ideas.
Will the user be able to zoom?
Will you allow auto-scaling?
Does the solution have to be a native function of the graph (are you willing to write code to do something LV does not support)?
If the answers to the above are no, no, no(yes) Then arbitrary marker spacing with code defined marker values should help.
Otherwsie, I watch for others to respond with their thoughts.
Ben
Message Edited by Ben on 03-13-2008 07:03 AM
(2,430 Views)
