Can I Redistribute the DAQmx Core Driver?
I am building a small application in .NET that uses NI devices and requires the DAQmx core driver. Is it legal for me to distribute the DAQmx core driver packaged with the software in a similar fashion to how the .NET framework is packaged with software packages that require it? Also, can anyone direct me to where I can find this writing?
(2,269 Views)
You can distribute as many copies as you wish.
Since you are using .NET you should have posted to a more appropriate board.
(2,260 Views)
