Can I Run a labview application in a hidden window (i.e. I don't want the front panel to pop up in this Labview created EXE)?
I have a executable labview 6.1 program with a front panel. The front panel pops up every time I run it. Can I force the program to run without popping up its front panel.
Thanks in Advance
Message 1 of 15
(7,420 Views)
If you're using MS Window, you can use lvwutil32.zip to hide the front panel. lvwutil32.zip can be downloaded from NI site.
Or you can move your front offscreen, so that user can't see it. And save your vi. When you run your vi again, it'll popup at the offscreen position. NI uses this trick to hide windows from LabVIEW users. You can also set front panel size to 0.
George Zou
http://gtoolbox.yeah.net
George Zou
Message 2 of 15
(7,419 Views)
Thanks, I think moving this off the screen will work for me.
Message 3 of 15
(7,419 Views)
In LabVIEW 6.1, a built VI [exe] must have at least one front panel open in order to remain alive. In LabVIEW 7 this has been addressed and an added functionality to LV7 front panels allows the user to define front panel window states, one of which is hidden.
Message 4 of 15
(7,421 Views)
Hiii,
        How to run the LabVIEW exe(Application) as a background process?
Nishant
Message 5 of 15
(7,087 Views)
Hi Nishant,
I noticed you also posted this question this forum. Please refer to the other post for an answer to your question and, in the future, refrain from making duplicate posts to several forums.
Michael K.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
Message 6 of 15
(7,057 Views)
I'm working in Labview2013 and I have the same request as Outlaw I wouldn't like that my FP pop up each the exe runs
Is anyone managed to do it?
Thank you in adavcne for your help
My best regards
Nadia
Message 7 of 15
(5,275 Views)
Hi nadia,
what's wrong with the recommendation to use the "hidden" property of the FP (as has been said 12 years ago)?
Message 8 of 15
(5,266 Views)
The exe is called by an application hundred times in one seconde, and the function hidden, hide the FP but doesn't close it, it appears as the picture below shown
Message 9 of 15
(5,234 Views)
Hi nadia,
I don't see any FP. Isn't this what you asked for?
When your "exe" is called "a hundred times per second" I would turn the functionality into a DLL and call that DLL from your other application!
Message 10 of 15
(5,227 Views)
