Can I acess vi from a .dll file which was complied from LabVIEW vi?
I have a .dll file which was complied in LabVIEW 7.1; is it possible for me to accesss vi inside this dll fileIf it is possible, how should I do?
(2,732 Views)
See here: Accessing VIs Inside of a LabVIEW Executable or DLL in LabVIEW 8.2 and Later.
So, since you have a 7.1 DLL you should be able to do it using VI Server functions, which you can read about in the LabVIEW Help as well as check out the examples that ship with LabVIEW.
(2,726 Views)
