Can I automatically get "This Connection is Required" on a VI's Connector Pane?
Correction.
It was Michael Avialiotis in his article "... - Readme First, All the details".
Ben
Message 11 of 15
(1,797 Views)
Ben identified the problem!
Yes, I had a special ini settings in the 7.0 installation. See this thread for details.
Message 12 of 15
(1,792 Views)
I wrote it in the other thread, but I will write it here as well - there are 2 seperate ConPane properties, the regular one, which is only writable, and the hidden one, which allows you some other stuff. They are not the same property.
___________________
Try to take over the world!
Message 13 of 15
(1,781 Views)
You can configure LabVIEW to set all new terminals you configure on the connector pane to required instead of recommended. Select Tools»Options»Front Panel and place a checkmark in the Connector pane terminals default to required checkbox. This option also applies to connections made using the Edit»Create SubVI menu item.
Message 14 of 15
(1,319 Views)
@stanLee99 wrote:
You can configure LabVIEW to....
You probably did not notice that this thread is 15+years old. Yes, a lot of features have been added since then. 😉
Message 15 of 15
(1,293 Views)
