Can I change Installer Product Version?
For example,
I got an exe version 1.0.0.0.
I needed to build an installer with product version of 1.0.0.0 too.
However it only allow 3 digits to be fill.
Is there any way to change this?
Thanks!
(2,984 Views)
Anyone know any workaround solution?
(2,930 Views)
Adriano,
It does not look like you will be able to get more than 3 digits for an installer.  What is your goal and what are you trying to do exactly that this is not letting you do.
I just want to get a better picture of what you want to do but can't so we can offer up possible workarounds.
(2,906 Views)
Product Versions are typically:
Major Revision. Minor Revision. Fix/Patch. Build.
Build is often not encluded in the Product Version since itis (mostly) a development tracking feature.
(2,896 Views)
