Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can I change a waveform to an Array?
weizbox
Member
09-24-2003
09:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Imhaving problems working with Datasocket and cant seem to send a waveform over it very easily, so I was wondering if there is a way to change a waveform to an array in order to send it over DS that way.
-Mark
0
Kudos
Message
1
of 2
(2,557 Views)
Reply
Re: Can I change a waveform to an Array?
Dennis_Knutson
Knight of NI
09-24-2003
09:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Use the Get Waveform Components function from the Waveform palette. You can select t0, dt, and Y.
0
Kudos
Message
2
of 2
(2,557 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
