Can I connect two computers to one device?
Can I connect two computers to one device? I am trying to have them control different aspects of the experiment that I'm running.
(2,840 Views)
If you mean one device being one DAQ card, then no, they cannot both control the DAQ card at the same time. (To me a device can be a DAQ card, a hard drive, a pistion, a power supply, a printer, a valve, a telephone, etc.) If you really do need two computers to control this experiment, then setting up network communication would be a solution to this dillema.
(2,840 Views)
That depends upon the device. If it's GPIB, you could
use the E-NET card to convert it to LAN. That would
allow control by many computers. The only problem with
that might be sychronization. That is, Computer 1 does
its setup. Then Computer 2 does a reset. Compuer 1's
setup is now gone.
As another poster suggested, you could always network
between the two computers.
Les.Hammer@CompleteTest.com
(2,840 Views)
