Can I counter how many 0s and 1s in a fixed size boolen array in one FPGA tick?
As a matter of fact, I did use 80Mhz to oversample 5M signal.
The thing is, if we are talking about fpga tick, we'll usually do it in a SCTL, make sure the job can be done in just one tick, so a for loop is not allowed.
I did try IPgen toolkit to convent for loop to make it effectively run in FPGA, the result is yes we can have such IP core running, but I will have 500 tick or so latch.
Divide the for loop to many 8bit array isn't help, the latch would pretty much the same.
I would accept latchs in most time, but in this application I need to trig external device to capture communication, If I only need to decode frame itself I wouldn't think that a big problem, only make same amount of sample in shifting registers would solve the problem.
Message 11 of 12
(914 Views)
Did you set a maximum latency constraint on the design to force IP Builder to attempt to decompose and pipeline the logic more efficiently? It may take some tweaking to get it to produce something that works for your design.
Message 12 of 12
(892 Views)
