Can I create LabView front panel objects on the fly?
I need to be able to create a front panel object, like a numeric or string, programmatically. Also I need to be able read and write to that newly created numeric. Does anybody have an example of that or explination on how to do that?
(3,226 Views)
No way !
However, if you're using MS Window, you can create Window
objects, such as the text edit window used in Notepad, at
run-time.
George Zou
http://gtoolbox.yeah.net
George Zou
(3,226 Views)
hi,
I would prepare all the needed controls - hide them in the background and let them appear programmatically via
property node "visible" = true and hide them afterwards.
possible idea ?
regards
wha
(3,226 Views)
Good idea, I could probably use Excel.
Thanks!
(3,226 Views)
