Can I create a multi-plot XY Graph in real-time, and if so...how do I make this a multiplot graph. I've attached what I have below. Thanks for any help.
See VI below for what I've tried. I'm able to do a real-time plot using the XY graph, now I just need to add a second signal on the y-axis.
(3,317 Views)
Hello there:
Yea Verily, there is a way to do this. Look at the attached vi for a project I've used for just such a purpose.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,316 Views)
Thanks Eric-
Could you attach the "XY Chart Buffer vi."? the main roadblock I'm having is determining what does the XY Graph expect at the Y-input. How do I wire my 2 Y-elements together to feed in the XY chart so that they can both be displayed against the variable X-axis?
Thanks again for the quick response, I'm just getting used to v. 7.0
(3,316 Views)
that should be in CHART examples, but just in case it's not...I've attached it.
good luck!
Eric P. Nichols
P.O. Box 56235
(3,316 Views)
