Can I create an I or D controller in LabVIEW?
I successfully tuned a PID Advanced VI to contol a process. Through trial and error, I found that the following gains worked best for me: Kc = 0.5, Ti = 0.01, Td = 0. Now, I would like to fiddle with a D controller; however, I don't think I can do that since the PID Advanced VI uses the standard form to calculate gains.
 Do I have to create my own "ideal" PID VI, or is there a way to create an I or D controller using the PID and PID Advanced VIs?
Many thanks!
-Farid
(3,676 Views)
I think there is a VI somewhere (control design?) that allows you to convert the gains between ideal and standard form?
(blog)
(3,640 Views)
I don't understand your question - the VI you're using is already a D controller (as well as P and I).
D is usually the trickiest to get right (for me, anyway).
Can you restate your trouble?
Steve Bird
Culverson.com
LinkedIn
(3,630 Views)
The PID Advanced VI uses the "noninteractive" algorithm seen in the picture below. This algorithm does not have individual Kp, Ki, and Kd gains; rather, the algorithm uses a controller gain, Kc, and integral and derivative periods, Ti and Td respectively, to control a process (which, according to the pic's site, is more intuitive and commonly used in industry).
http://blog.opticontrols.com/archives/124
However, this means that I can only create a P, PI, PD, or PID controller. I want to fiddle with a D controller. Can I do that with the PID or PID Advanced VIs? If so, how?
Farid
(3,595 Views)
Found it! PID Structure Conversion VI
But a lone Ki or Kd term still won't affect my PID Advanced vi's output (with Ki and Kd ranging from 5E-7 to 5E7). Am I wiring the PID Advanced VI incorrectly?
-Farid
(3,576 Views)
I have the same question that I'd like to do something like I-control, but it seemed the p-value is necessary in PID toolkit...
As a result, I made the p-value as small as possible and got the corresponding I-value I need.
I'm not sure my methond is correct, and looking for some other ideas.
My objective is to control a temperature chamber by PID control.
For example, the chamber is set 37 degC, but the sensor we're interested in is 36 degC.
I use 37 degC as the SV, and the measured value of the sensor as the PV, and I have to generate an output to set the chamber dynamically.
What my idea is I can get the accumulated integral error as an offset to the SV so that I add the output of the I-control with the SV as a actual output to set the chamber.
P value is trivial to me in this way since when the error is zero, the output is zero, and have no offset to the output, like the following image.
(3,527 Views)
