Can I create an application with a few exe files in the output folder?
I have a project containing a few classes. There is a main class where I create top level test VIs. Every time when I design a new test and built it I have an output with a single exe file and a lot of folders containing VIs from other classes. LabView can not place this in one exe. OK! Every time I make a new exe from a new VI I have a new output folder containing the same VIs hierarchy. Is there any possibility to just add new VIs to previous build specification to just get an additional exe file in the output folder?
Message Edited by Alex67 on 12-08-2009 11:39 PM
(2,588 Views)
