Can I create an executable that includes my scaling?
Is it possible to c reate an executable VI including scaling, for use on multiple systems? Please include instructions.
Message 1 of 9
(3,879 Views)
What type of scaling did you have in mind? The easiest way to do this is to scale the data yourself in your code, then your scaling follows your code in whatever form the code takes (VIs, executable, ppl, etc.).
Message 2 of 9
(3,866 Views)
For Strain gauges and O2 analysers. How do you build it in the code? I use DAQ assistant.... Is it still possible?
Message 3 of 9
(3,858 Views)
Sure there are lots of ways.  Your scaling is stored in MAX, Measurement and Automation Explorer.  There you can export all kinds of DAQ settings, and then import them on another PC.  You can do this manually, or programatically at the start of your program, or on installation.
http://digital.ni.com/public.nsf/allkb/12288DEB3C6A185B862572A70043C353
http://digital.ni.com/public.nsf/allkb/E8E00D0F0C05823886257522007E66FA
Message 4 of 9
(3,836 Views)
We are doing this already. I was just wondering if the scales could be put right in the executable due to the fact that we use multiple PC's and DAQ units for our testing.
Message 5 of 9
(3,805 Views)
Don't use the DAQ Assistant. With the much more flexible DAQmx functions, you can put whatever you want in the VI itself.
Message 6 of 9
(3,798 Views)
You can do a number of things.  This shows that you can create a scale and save it in MAX.  One idea would be to query available scales when your program starts and create them if they don't exist.  The sky's the limit.
Jim
Message 7 of 9
(3,796 Views)
Keep your project all together.  Add the Task and Scale to the project.
if you look inside this build you will find
\Data\NI-DAQmx.ini
[DAQmx]
MajorVersion = 9
MinorVersion = 8
[DAQmxChannel ProjectVoltageTask/Voltage]
AI.MeasType = Voltage
AI.Voltage.Units = From Custom Scale
AI.TermCfg = Differential
AI.Max = 10
AI.Min = -10
AI.CustomScaleName = ProjectScale
ChanType = Analog Input
PhysicalChanName = Dev1/ai0
[DAQmxTask ProjectVoltageTask]
Channels = ProjectVoltageTask/Voltage
SampQuant.SampMode = Finite Samples
SampClk.ActiveEdge = Rising
SampQuant.SampPerChan = 100
SampClk.Rate = 1000
SampTimingType = Sample Clock
SampClk.src=
[DAQmxScale ProjectScale]
Lin.Slope = 1
Lin.YIntercept = 0
PreScaledUnits = Volts
ScaledUnits =
ScaleType = Linear"
Right there in the exe.
Message 8 of 9
(3,773 Views)
Thanks I'll Try those suggestions.!!!!!!!!! 🙂
Message 9 of 9
(3,769 Views)
