Can I directly communicate with an EnDat Sensor or do I need an interface?
We are using cRIO with FPGA and some DIO interfaces (NI 9411 and NI 9403). Until now we had incremental signals which are easy to detect with the DI module. But now we are have an absolute signal with this EnDat signal. Is there a way to add this signals (1Vss) ant the absolute ENDat interface with standard cRIO modules? We don't want to add an additional third party module as the EnDat Module from SEA.
Od do ou have other references to get an absolute signal?
(6,398 Views)
Hi Peric,
I want to help you out with your request.
What do you mean with incremental and absolute signals and how do you want to communicate with the EnDat Sensor?
Joaquin
(6,375 Views)
Accepted by topic author Petric
Hi Petric,
sorry for the questions, it's clear what you mean now. After some researches i can tell you, that it is the best solution to use the EnDat Signals is the cRIO EnDat Modul of SEA. National Instruments doesn't offer EnDat Modules, because we can't cover the whole spectrum of Modules and the EnDat Protocoll/Signal is very special and complicated. It ensures you reliable FPGA speed at a maximum data rate of 38 kHz and is a qualified product which is full supported from our cRIO Chassis. So if you want to use the EnDat Signal i would recommend you the Module from SEA. If it's possible to use other Signals like SSI, Hiperface you can look after other solutions.
EnDat 2.2 - Bidirectional Interface for Position Encoders
http://www.heidenhain.co.uk/de_EN/php/documentation-information/documentation/brochures/popup/media/...
I hope I could help you with your question.
Kind Regards,
Joaquin
(6,370 Views)
Take a look at this device from Heidenhain.
http://www.heidenhain.us/Portable-Interface.htm
(6,367 Views)
Manual for the EIB741 interface.
(6,365 Views)
Thanks for the information. It's no what I hoped to hear but when the protocoll is so complicated, it seems to be the only good solution to get the cRIO Module from SEA...
(6,340 Views)
thank you unclebump for your idea with the interface but we don't want an additional part in our controller box...
(6,338 Views)
