Can I distribute wrapped VI as DLL?
I am working on a project that has some components written in LabVIEW and others in C++. The C++ code requires a function that would most easily be implemented by wrapping a single LabVIEW function as a DLL. Is this okay from a Licensing perspective?
To clarify, if I have a valid license to create DLLs with LabVIEW and distibute them, can I distribute a dll that wraps a single LabVIEW function? This is for use within a larger project and not an attempt to provide a toolkit of wrapped LV functions for use by a third party.
(2,589 Views)
Accepted by topic author ToeCutter
Since you have the right to create DLLs i dont see why not. Isn't the whole point of DLLs to wrap more or less complex functions? 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,577 Views)
Thanks. I ended up ringing NI and they say there is no problem with it.
(2,573 Views)
