Can I divide and multiply complex numbers in Labview without converting them fir
(4,471 Views)
Hi gullon,
yes you can. You can simply try it. 🙂
Please use the textfield for your description and not only the subject.
Mike
(4,468 Views)
Hi Gullon,
this is called "polymorphism" in LabView: most functions can adapt to the supplied datatype. You can multiply complex numbers the same way as integers...
(4,464 Views)
