Can I do a synchronous transmission with a NI2954R @50MS/s using 10G Ethernet instead of PCIe?
Hi, I'm currently using a NI-2954R to send an OFDM signal @ 50MS/s synchronously using an external 10MHz and a 1PPS signal. In our application, we are not using a chassis with PCI connection but a PC with 32GB RAM, SSD memory, and a 10G Ethernet port.
The VI I'm using is a modified version of example VI "niUSRP EX Tx Multiple Synchronized Outputs (PPS Trig)"
Is this enough to transmit the signal we have at the speed we want?
Cheers
Jorge Gomez
Message 1 of 1
(1,251 Views)
