Can I do the hardware I/O in labview under windows 2000?
I can do the hardware I/O directly under windows 98,
however I cannot do the same operations under windows2000. I am using the version 5.1. I'd like to know if I can do it with the new version 6.1.
(2,664 Views)
If you go to http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/49664743ded6f1da862564bc004e3a7f?OpenDocument you will find VIs to do it in either 5.1 or 6.
(2,664 Views)
That's exactly what I need
(2,664 Views)
