Can I drive a proximity badge reader with LabVIEW v8.0 ?
I have a proximity badge reader system in my facility;  the brand name is HID.  I would like to expand the use of those badges to a LabVIEW application on the shop floor.  But, I need to know if LabVIEW can drive a badge reader.
The proximity reader that I can buy from HID that will work with my existing badges has an RS232 interface.
Would that work ?
Thanks.
(3,000 Views)
Should be able to do it. Sounds like it will work like a barcode scanner. Do a search on the forums for barcode and you should find all kind of implementations.
(2,988 Views)
If it has an RS-232 interface, you should be able to do it..
It may simply send an id-tag when it is in proximity..  The proximity simply sends enery to a coil (transformer) which activates the chip to transmit a small RF signal containing the badge id.
(2,980 Views)
Oh, yeah.
I forgot to mention that I do NOT want this to function as a keyboard wedge.
Martin
(2,957 Views)
You'll need to get details on the serial protocol from HID. Once you have that and unless they are using some really non-standard setup, you should be able to try the shipping examples for serial communication.
(2,954 Views)
