Can I dynamically remove vi's.
Is it possible to dynamically remove vi's? It does not seem possible with the vi-server-functions.
(2,927 Views)
If you dynamically load a VI, you can dynamically remove it by closing the
VI reference.
If it's a VI that has been loaded because it is part of another VI you
cannot unload it while the parent remains in memory.
I've never had to close a VI that has been arbitrarily loaded by the user,
but I think that you cannot have a VI in memory if its front panel is
closed, it is not running and it is not a child of another loaded VI. Hence
I think you can close such VIs by closing their window, which is an
available property.
casimir wrote in message
news:506500000008000000062F0000-1003545641000@exchange.ni.com...
(2,927 Views)
