Can I edit the data already displayed in tree control?
I'm using a tree control to display some data in front panel. But after running the program, can I edit the data already displayed in tree control by using input control and let it change and display dynamically? In invoke nodes I can only find add or delete items in tree but can't find edit...
(3,178 Views)
There is no direct editing option available, same can be achieved in two steps by using
--> Add Item Invoke Node
--> Delete Item Invoke Node
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,166 Views)
Thx! But I wanna keep items in first column unchanged and just let data in second column change dynamically. Is it unachievable by using tree control?
(3,159 Views)
You can use the 'active cell --> cell string' property to change the value in a particaular column.
(3,137 Views)
Thx. I'll have a try.
(3,129 Views)
