Can I enable LabVIEW to select a NI Scope Device automatically instead of the user selecting manually?
Hi, is it possible to programmatically select a NI Scope Device instead of allowing the user to manually selecting device? And use this data as a resource name input for niScope Initialize?
What I want to do is allow LabVIEW to search the MAX find the available NI Scope Device and introduce this value into the resource name input of niScope Initialize. I have tried various ways(NI DAQmx device property node, NI Scope property node, Get DAQ Info.vi) but I cant convert the data into IVI Session of class niScope.
(3,388 Views)
Accepted by topic author bermea
For NI-SCOPE devices, you can use the NI-ModInst interface to query for what devices are available.  It is buried in the Utility Functions in the NI-SCOPE palette.  Or you can search the palette for NI-ModInst.
(3,362 Views)
For newer readers of this thread, NI-ModInst has been largely replaced by the System Configuration VIs (Measurement I/O»System Configuration).
(2,974 Views)
