Can I execute a sub VI mutilple times at the same time using Reference Nodes
I want to call a subVI multiple times depending on the test. I can create multiple References but once I execute one Reference, but it I get an error 1000 when i try to run the second Reference.
(2,866 Views)
Try making the SubVI reentrant.
(2,866 Views)
Making the subVI reentrant will do the trick but please make sure you wire an 8 to the options input of Open VI Reference. This will prepare the target for a re-entrant run and it will execute in a parallel data space.
I hope this helps.
Sincerely,
Feroz
(2,866 Views)
