10-24-2005 04:58 PM
10-25-2005 03:26 PM
Hi Ashutosh,
This driver:
http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E959A659CE034080020E74861
appears to require at least LabVIEW 6.0. I haven't been able to find a driver for version 5.1. If you have a newer version of LabVIEW, you can open the driver VIs and reproduce them in LabVIEW 5.1. This is a plug and play driver that just uses GPIB commands. Instrument drivers are only available as a download. We don't have a hard copy of the drivers to send out. You can always download them to a USB key or a floppy disk to transfer to your computer.
10-25-2005 04:26 PM
Here are pictures of the vi's in the lockin amplifier. I've saved the 7 frame sequence file ;-( as a flat sequence which wouldn't be available in LV 5.x but aids in seeing how it is all connected together. I don't have a way to save it earlier than 7.0 at the moment, so figured I'd send the pictures, you should be able to wire it fairly quickly. I don't see anything that won't be available in 5.x (other than the flat sequence that I mentioned).
Hope this helps, good luck
P.M.
10-25-2005 04:29 PM
