Can I get a feedback on my code?
I'm filling out an array with letters (from A to Z). Please run the code and see the behavior. I want my code to work as it's working now. What do you think about what I'm doing? Is it good or bad?
Feel to criticize.
(1,560 Views)
Bad! Way too much duplicate code and unnecessary complications! You are also indexing outside the valid array later.
(1,542 Views)
See if this can give you some ideas:
(1,533 Views)
Accepted by topic author GRCK5000
Here's what I would probably do (make sure to learn about the output configuration of the addition. Needs to be U8):
(1,525 Views)
Wow. Next time, Thanks Mr. Altenbach. So, now I learned to avoid duplication, I should be using for loop. Thanks!!! You made this very simple. Awesome!!!
(1,518 Views)
