Can I get a stepper motor to work useing an AO channel on a DAQ card?
Can I get a stepper motor to work useing an AO channel on a DAQ card? I know its a very low currentl coming out, but what Im going to be using the motor for is very weak. Has anyone tried this before? I certinaly dont want to spend 2,000+ on somthing that will be basicly moving a string on some pullys back and forth.
-Mark
(2,628 Views)
Greetings, Mark
You can certainly use the A0 as a driving signal, but you need to amplify the current considerably to run a stepper motor. Additionally, most stepper motors require multiple phase driving signals to work properly. If I understand your application, I believe a stepper motor is a bit of overkill...you only want to use them when precise positioning and repeatability is an issue. You might look at some of the linear actuators available.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,628 Views)
